Specifies whether an NTP key is trusted or not trusted.
keyid | Specifies the key ID as a value from 1 to 65534. |
trusted | Specifies that the key is in trusted status. To use a specific key for an NTP session, set the key to trusted status. |
not-trusted | Specifies that the key is in not trusted status. |
An NTP key is not trusted by default.
After an NTP key is created, the generated key is not-trusted by default. To use a specific key for an NTP session, the key must be trusted. The trusted option changes the key to trusted status. The not-trusted option changes the key to untrusted status.
The following command changes NTP key 1 to trusted status:
configure ntp key 1 trusted
This command was first available in ExtremeXOS 12.7.
